Battery went dead, could jump it off, but as soon as you disconnect jumper cables it dies.    Installed new battery, new cable ends pos neg.  Cranked up, used around the property all day, turning it on and off.  Went to crank and move it to garage, dead.  Same thing, jumped off, disconnected cables and it quits. I think it’s a grounding issue, but I have no idea from where.  Any suggestions?
    • By SpaceGhost
      Hello All...
    • By Rainman
      Thanks in advance ...
