  • Alex changed the title to Yamaha Rhino 660 radiator fan on a Massimo MSU 500?
Okay, I purchased one listed for a Rhino 660 off Amazon by a DB Electrical. The bolt pattern was different so I had to drill new holes and the wires in the receptacle were reversed so I had to switch those....but then it worked great! Lol
No, it was pretty easy. It was more work getting the radiator out. I had to pull the passenger side shock off and take the sway bar links loose then pivot the sway bar down and out of the way.
    • By NC4wd
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By mac66
      The good...
      -Fairly comfortable to drive.
      The not so good...
      Overall Impression...
    • By PossumTruck
      Greetings,
