  • Alex changed the title to Yamaha Rhino 660 radiator fan on a Massimo MSU 500?
Okay, I purchased one listed for a Rhino 660 off Amazon by a DB Electrical. The bolt pattern was different so I had to drill new holes and the wires in the receptacle were reversed so I had to switch those....but then it worked great! Lol
No, it was pretty easy. It was more work getting the radiator out. I had to pull the passenger side shock off and take the sway bar links loose then pivot the sway bar down and out of the way.
    • By Jr Perez
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
      My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
    • By Jerrys500
      Thanks Jerr
    • By JimG
    • By Rider
      I have a 2021 Massimo T-Boss 410 and it needs the cv boots replaced.  Has anyone had to replace the boots on their T-Boss?  Does anyone know where to get replacement boots?  Are there boots for other ATV/UTVs that will fit?  The Massimo parts site only sells the entire axles.  Thanks
