Went for a short ride yesterday and didn’t realize it was going to be shorter than expected. Started heading up a hill and then started to miss and then died. The first thing I thought was here we go, it’s now started it’s first failure of many to come. Well lucky for me I opened up the bed and after scratching my head for ten minutes, I happened to look at the spark plug wire and it had backed off of the plug just enough to loose contact. After burning my hand on exhaust, (lol) I took a pair off needle nose pliers and squeezed the contact a little smaller and then snapped it back on and been perfect ever since. Just wanted you guys to know in case this happens to you. Only takes a second to check to eliminated this issue going forward.
Regards, Rick
    • By camojay
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
