Trying to decide whether to remove doors or not. They make it more difficult to get in and out of cab. Has anyone removed there doors and if so, is it better or not.
Regards, Rick
  • Roadstar515 changed the title to 2022 Hisun 750 door remove or not
Scott, took your advise, removed one band on each side and made a big difference. I’ll try that for a while and see if that will be the way to go instead of removing door completely.
thanks, Rick
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By mark walkom
    • By mac66
    • By sxr951
