I just replaced the OEM Discovery batteries in my 2017 E1 with Trojan T-105's.   The dealer reprogrammed the charger for these batteries.    I use the E1 almost constantly around my farm,  but seldom put more than a  a few miles a day on the rig.   As I don't need long range, it was recommended I stay with lead acid batteries as the cost became a significant factor.    My question is it is better for the batteries to charge my E1 every night or to run it a week or so and take the charge down  a ways before recharging.
As long as you aren't discharging below 50% on a lead acid it shouldnt make much difference.
I'm not familiar with those specific batteries and charging setup, but there are other issues that come with using multiple lead acid type batteries. One is that you will need to periodically do an equalization charge to keep the batteries equal. This is true with any multi-battery lead acid setup. Typically on a multi battery solar home this is done monthly and is accomplished by charging at a slightly higher than normal voltage, should be similar on a battery powered vehicle. The other concern with leaving it on the battery charger all the time would be electrolyte evaporation. If it's a wet type battery you would want to check and make sure the cells are full periodically.
If its had the correct algorithm put in then the DeltaQ charger has a balancing phase. Although that overcharge can be a bit to aggressive as on the Rangers which also use Trojans, and many people suffer because the batteries gas a lot, that rusts out the base plates and chassis (I just replaced a section of rusted through chassis on a Ranger)  You must also water the Trojans to repace the lost / evaporated water on a regular basis. If not then they really wont last long at all. Thats one reason why Hisun went for the Discover , as they dont need maintenance, which many people just dont do. On the deltaq charger there is a small rubber cover on the drivers side front, above that is a display. If you push the plastic cover above the display (Above as in going up from the ground, ) you will eventually feel a small clicking push switch. Dont push too hard just move about that area until you find it. Then while pushing the switch, plug in the mains, it will then show a P123 number. note that number and let go. Thats the algorithm thats in use. Post that on here.  And dont leave it too long before charging as its easy to let them get too low, you (or someone else jumps in and thrashes it and hey presto you have badly flattened batteries. The rot sets in as soon as you start to over discharge and pull high currents, especially if the watering hasnt been done adequately.  Juts work out what works for you ideally dont let it get below something like 50 to 60 % especially in the winter. In summer try and keep it out of the heat when charging that lessens gassing (its cooler to start with). Heavy discharge is not good for any Battery, deep discharge included. And especially when new.  The Trojans are also a bit less Ah than the Discover, although they both express the Ah in different ways. The Trojan is around 15% less capacity. So again dont expect the range you once got.
    • By hisun junk
    • By Reynolds Rocket
    • By Kingfish
      I have done a LiPo4 battery upgrade on my E1.  I have reprogrammed the charge profile to #386.  With the onboard BMS the controller cuts off all charge from the IC1200 when the battery reaches 100% to prevent overcharge.  When this happens the charger begins flashing the yellow light and displays the error code 013 which is telling me the battery is no longer accepting a charge input which is as it should be.  I hear a relay switching in and out every few seconds as the charger continues to try to reach the shutoff charge profile voltage.  My question is will it cause any harm to the IC1200 to stay in this state for hours or maybe even days if I don't get out to unplug it?  I used to leave the E1 plugged in all the time with the old Discover batteries.
    • By Jerrys500
      I wouldn't say that after a year of owning this thing, that I would go out and buy one again. Certainly one that was used and abused, but at the time I needed something and this was in my price range. I could tell that it would need some work. I however didn't know the half of it. This was my second UTV. The first one was and older American Sportsworks Carbide 7150 that was a total piece of junk. I got it for next to nothing and was a project piece. I got it running and rode it for a bit but it was way not what i needed and it finally burned up and was set aside. Anyways, so I bought this one from a farmer. I'm not positive of the exact model but it originally came from Tractor Supply. per the stickers on the bed and its a camo color. Upon first inspection when I got it home, it was a mess.
      1. Had a water leak - The leak was in two hoses one of which was a short one that came from the rear of the engine and I literally ended up cutting it off. Well getting another one on there took hours and was simply horrible.
      2. Had an oil leak - This is my concern today as I was never able to figure out for sure what it was going to take to fix it. More on that in a min once you have a full account of where i've been in this thing.
      3. Had a bad clutch - Replacing the entirety of the clutch system wasn't all that bad except its a tight space to work in to do this repair. was a pain to figure out the angle that I needed to get the cover off and then back on again but figured it out the second day and got it done.
      4. Had bad Universal Joints - this was a nightmare because they originally put 18mm ujoints in the thing which I was not aware of so when my parts came in of course I had the 20mm that they started putting in, from what I can understand, was the very next year. Finding the 18mm ones was all but impossible so I bit the bullet and did the full conversion to the 20's.
      5. Had bad Tie Rods.  - Tie rods were not a problem. However while in there I noticed that it was a little low on brake fluid. The fluid that was in there looked fresh. Sure enough there was a line leak there so i had to get new lines for it. I almost just ordered the master cylinder at that time but had seen the  fluid coming from the other end and thought yeah it should  be ok. That was a stupid decision. Yet another parts order to get one. Once delivered it was not a prob just replace, fill, bleed and good to go.
      6. This was about the time the panic set in. I needed to check the other oils and the final gear oil was mostly empty and what was in there I'm still not was sure was gear lube. Luckily after clearing it out and refilling it, there didn't seem to be any issues with the final gear. So far that is.
      7. So at this point I figured that it was ready for my first trek with it to the  gold claim and off  we went. This was a 14 day venture in the middle of nowhere over 300 miles from home. I had tested it over the course of 5 days and except for the oil leak it looked like all was good with the exception of blowing a little smoke. Day two in the sticks it decided to just die on us out of the blue. I checked the spark and it wasn't there anymore. The plug wire had come apart. I made one that worked until I could get a replacement. It still wouldn't start but I was getting spark. ended having to remove the fuel pump and clean it up. I then had to pull the fuel injector. I don't know why it ran when it did. It took over 4 hours of running brake parts cleaner and air through it before I could get any fuel to go through it. Luckily after that most of a day delay, I'm glad to report that it did its job rather nicely for the remainder of the trip.
      8. After that ordeal and in the neighborhood of about $800 or so for parts and oils and all it looked a little brighter. I did still have not only the oil leak to fix, it started blowing more and more smoke. I keep the oil up but it uses quite a bit. if used in a whole day I'm adding at least a half quart. Its made three trips now in this described state. The only new things are that it has gotten very difficult to shift which is likely that pair of shifting gears, the blowing of smoke that is almost for sure a sign that I have to rebuild the top end including the top end kit and do the valves at the same time. Now the oil leak.
      So this leak I don't quite know the part names but it is coming out from around the shaft coming from the front of the engine. My diagram does not seem to show that there is a bearing in there but I would think there has to be. So I can't order a part that doesn't seem to exist. Now the part I still can't figure out is am I going to have to pull the motor and split the case to do this repair or with the four bolts in the housing will this pop out into my hand and be a simple replacement? Of course after removing that shaft which of its own was no fun because of the requirement of almost having to remove the entire differential to get it out.
      Sorry for the lengthy story but I think that it shows some of the pain of these things. I grew up riding dirt bikes, motorcycles, and three and four wheelers and I can say that none of them were ever as difficult to fix stuff as this Massimo is. Heck have done motorcycles from the frame up with modifications and it wasn't this difficult. Let me  qualify that statement, I'm speaking of Kawasaki, Honda, and Suzuki motorcycles only once did ever work on a Harley and thinking about it that was horrific as well.
      Thanks for any words of wisdom besides junk this crap for a 17k to 30k upgrade. Only cause I'm 5'9 and my wife of 40 plus years is 6'1 and told me that i can't have the Kawasaki Teryx 1000 that I drool over. Getting old has really curbed her desire to deal with my toys over these four decades....
      Thanks for listening I look forward to and replies... Jerry
