Bobcat 2300/3450 Pallet Fork Attachment For Sale
By JimG
By PossumTruck
Greetings,
I have a client that wants me to install a heater of some sort to aid in cold weather starting (she uses it at her business, has had issues starting the last few days in sub-zero). I would prefer a coolant heater to a pan heater (silicone pad), but I cant for the life of me find the diameter of the coolant hoses. Heck, I'm not even sure if it would work as well in this application given how long the hose is compared to tractors and trucks I have installed them in.
Any advice you could give me would be GREATLY appreciated.
By Texas Rider
Okay guys, this Vector 500 is killing me. Hisun 500cc engine (Chinese) About a year ago while riding slowly, I heard a tink and UTV turned off and would not start. Checked everything long story short, timing chain jumped off lower sprocket, slightly bent the cam sprocket phasers. Bought new chain and cam sprocket, set everything back to timing position, mounted chain on lower shaft sprocket and upper cam sprocket. Set the tensioner, cranked and poof, chain once again jumped off lower shaft sprocket. Again, repeated proper timing settings, remounted chain, cranked and poof again and again and again, chain keeps jumping off lower sprocket. Just to be clear, valves, piston and all components are look in great condition. Can't see shaft sprocket but to the finger behind the tight squeeze, all sprockets seem to be in place, or maybe not. Tired of fiddling with it. This was bought brand new at Home Depot and has less than 200 hrs in the past 3 years. Don't tell me to warranty it as that expired one year in. Talked manufacture out of McKinney TX and service tech was no help. My question to you, what am I missing? What next?
Dumbfounded 🤔
By Richard shepard
I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
