I have a 2013 Coleman ut500. When riding I get a lot of heat coming from behind the seats. Has anyone put some kind of heat shield to stop this heat? It get quite warm on long rides! T.I.A.
  • Alex changed the title to 2013 Coleman ut500 Heat coming from the rear
Plan on doing something like that to my axis. Something else I plan on doing is a pair of 12 volt radiator fans way up high tied to the ROPS (roll over protection system). Then have passenger and driver rocker switches.
Should provide plenty of air. Plenty of air comes in at the top of windshield. And help keep dust out of cab. I have a rear windshield. That helps a LOT but still gets a little in.
There are self adhesive rubber sheets with foil backing that are heat resistant and will help reflect the radiated heat you could try. As a bonus they also deaden noise. They are available for example, on Amazon, for relatively cheap.
I'm not familiar with that particular model/year but presumably like the other older models the cylinder slants forward under the driver's seat? If so it will be harder to deal with the heat due to the proximity of the cylinder. All the newer engines the cylinder slants backwards and is under the bed.
You also need to be careful what you block off for airflow around the engine because there are parts that require airflow to keep cool even on a nominally water cooled engine.
I had that same issue with my Massimo MSU500 .. Tried shielding the cab.. heat was still coming in everywhere . it was very hot with our  100* days here. The heat was coming from the outlet of the mechanical fan on passenger side. The duct exited right between the seats rear. And it was very hot!  Turned out it was because  the engine  was running 240* and soon blew the head .. after getting it all repaired couple times, we bypassed the factory sender on radiator and ran electric cooling fan 100%.. guess what, no heat in the cab .. When winter came we installed an adjustable controller to keep the engine between 160*-180*..   All is well now and you can put your hand on that duct on a hot day.
Thanks, but on mine you can see the exhaust right between the seats and the console. I believe that's where all the heat is coming from.
thats were my exhaust pipe is too.. right next to the duct that flows the heat out of the engine s mechanical fan ..it pulls air from filter box , thru rt side of engine cover and out thru duct between seats.  Its not hot anymore. the exhaust pipe is but the heat is not in the cab now .......... good luck
Do you have pictures on what you did?
    • By Mike Jenkins
    • By Marie
    • By Marie
