2013 Coleman ut500 Heat coming from the rear
By Rainman
I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
One search online showed a 6v, but another stated 12v..
I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
Can anyone verify what volt (6 or 12) the batter is?
Thanks in advance ...
By SouthernGypsy
By Robby
By Howard Elmore
