Can anyone tell me what the bolt pattern dimensions are on these troopers? also, if anyone knows what the back space of the wheels are that would be great thanks.
Kevin
Backspacing is 4" in the front and 6" in the rear. Front spacing is 2" both front and rear. The additional 2" of backspacing of the rear rims is the reason the rears can't be used in the front. The rear rims hit the tie rods.
rocmoc n AZ/Mexico
Did an edit on this rocmoc, you meant to say rears CAN'T be used on the front, Right? kinarfi
Backspacing is 4" in the front and 6" in the rear. Frontspacing is 2" both front and rear. The additional 2" of backspacing of the rear rims is the reason the rears can be used in the front. The rear rims hit the tie rods.
rocmoc n AZ/Mexico
Thanks rocmoc, do you think a 5" backspace will fit on the front, or does it need to be 4"?
Kevin
Pretty sure 4" is the most you can have. My new rims are 8" but with 4" back & front spacing. The greater than 4" backspacing rim will mount on the hub but when you turn the tie rod is hit.
rocmoc n AZ/Mexico
  • 10 years later...
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By SouthernGypsy
    • By se3388
      Steve.............
