    • By allinone
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By Frank in MI
      Thanks for accepting me!
      Haven't got a side by side yet, but have been shopping.
      Any advice welcome & I am on a limited budget, so haven't decided yet on new or used.
    • By Browner010
      Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
      Any Ideas what to look for would be appreciated.
