I have a 2013 Massimo MSU 500 project. I just recently got it running after sitting in pieces for an unknown amount of time. I replaced the wet clutch and drum, the primary clutch and belt, the spark plug, ignition wire, and ignition coil. I cleaned the fuel tank, replaced the fuel lines, fuel and air filters. I adjusted the valve lash and  the throttle cable stroke. Now to the problem. It tops out in high gear at about 4400 rpm at 27 mph. It tops out in low gear at 5200 rpm at 28 mph? It will rev to about 7500 rpm in neutral. I'm guessing I just don't have enough horsepower for some reason. Ideas?
No, I picked this thing up for $50. It's the first SXS that I've ever had. Just trying to figure this thing out as I go. No manual or anything. I've got to dig out my compression gauge. It's in this shop... somewhere. lol
Update: I just ran a wide open throttle compression check and it's 135! According to the stats that I dug up it's supposed to be between 163 and 210. So, that's not good. Also when I removed the spark plug it was chalky black with soot. So I've got something else going on, I'm not sure what yet. Grrrr!
No, it wouldn't, but I don't think the low compression would cause the spark plug to soot up. That's a definite sign of running too rich. If one of the sensors is sending an erroneous signal to the ECM it could cause it to run rich.
Well now, that's a good thought. Tomorrow night when I get home I'll redo my compression test and this time I'll add a little oil. If the compression improves, it's rings, if not, it's valves. I new that just didn't think to do it. Thanks!
Okay, so I'm in the process of rebuilding the top end of this machine and I can't find any timing marks on the cam. No notch, no dot, no painted tooth, nothing. Does anyone know what it's supposed to look like?
  • 10 months later...
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By downseast
      Hi everyone
    • By D MAYNARD
