Oil filter disection
I've been looking for a cross to a filter from a known manufacturer since I bought this machine. Both from a cost standpoint, and a known quality standpoint. The factory filters are just plain black with no markings. Due to price point on these machines I would assume that the factory filter would be made as.cheap as possible
I have not had any real luck finding a cross, so In doing my first oil change I decided to cut the factory filter and see what is inside.
I don't have a fancy oil filter cutting set up, so I just clamped it in the vise and went to town with my portaband. Excuse the rough cuts and metal shavings.20220721_105045.thumb.jpg.abcbee34d9e48418140541c4bee355b0.jpg
Looks like a good quality filter, plenty of pleats/surface area. Metal endcaps. Excuse the crushing, that's from the vise/strap wrench to remove it.
Relief valve
And a spring in the bottom of the can to keep the top silicone anti-drainback pressed in place.
Overall looks like a surprisingly good quality filter for a no name. At least we can know that using the factory filters on these should be acceptable. I feel better about paying $10 for this filter at least knowing it's good quality.
  • Thanks 1
Link to comment
Share on other sites
  • 2 months later...
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
    • By GWS
      I am looking for the part numbers for the primary and safety air filters that will fit a 2020 Tracker 800SX
    • By diamondjfarm
      Thanks.
