suspension location dimensions
Guest Lenny
Someone asked me for the dimensions of how I did my suspension. I'm sorry, I got sidetracked and then forgot who it was. Now I can't find their post. Let me know who you are and I'll be glad to give you the information.
I was looking over all the suspension posts trying to figure out whats what. It seem like every month there is another topic on aftermarket suspensions, which to me indicates continuing interest. There is a well documented template on this site (with pictures and specs) but it is hard to follow through the treads. I had asked for general interest what the specs on your equipment were and any differences you may have made on construction. I might add that your pictures are also very helpfull - thanks.
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Kingfish
    • By Woody77
      UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
