suspension location dimensions
By JSwearer
Does anyone have any suggestions for aftermarket shocks. I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
By rev6engines
Call or Text:
801) 489-8697
Email at:
[email protected]
Happy riding!!! 🤘
By Kingfish
By Woody77
