Hi..my machine is hard to crank most times. Once it catches, it's fine but it takes multiple attempts and usually a jump start to make it start. Installed a new battery with same result. Is there a higher torque starter available? 2018 TBoss 500. Thanks in advance!
Best guess given the limited information is the starter wiring is to small. I have seen this in other Massimo models. Try replacing with #8 wire. To test If this will help,
use a fully charged car battery and jump with good quality cables directly to the starter motor terminal. Also, use a good ground next to the starter. Could also be a bad starter or other issues.
  • Thanks 1
    • By KWinTX
    • By Mike Jenkins
