Okay I'm looking for some technical help. I bought a new Throttle Position Sensor for my Massimo MSU 500 and I'd like to know the correct procedure for setting it up. I've set one on my Fox bodied Mustang several years ago but I can't remember how, or if it would even be the same. Haven't had any luck finding a YouTube video on it. Any help would be greatly appreciated. Thanks!
    • By CapnWalleye
    • By CapnWalleye
