Has anyone had bad ecm. I think I do because my fan runs all the time and it leans out and doesn't respond to O2 signal quickly. I replaced the O2 not the issue I have a afr gauge on it and it goes lean but the computer doesn't respond. I can drive part throttle and the engine dies and comes back back and forth fuel pressure and ignition are good. Anyone have a issue like this or have any input?
Trace all your wiring from O2 switch all the way back to the ECM. Look for rubs that could cause shorts in your 02 harness.
We had a similar problem with our T4 and the wire was rubbing on the starter and all of our wires had melted together in the 4 wire harness.
Also the dealer let us pull our ECM and he put it in a new trooper just to make sure it was not a ECM problem. Good Luck.
George
Ya its the computer its sealed up tight like a screen door. My dealer changed them before just like dropping your phone in the water. I tried it all to and I am a mechanic its the computer buddy almost positive got one coming
    • By CapnWalleye
    • By CapnWalleye
    • By Grant
    • By staind
      thanks Dan D. aka staind
    • By mcraigchr
      Howdy y'all,
      Craig C.
