K-Mule 4010 Oil Leak
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By mark walkom
By John M in Louisiana
Quick question about replacing the plug. One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs. 15amp 125v? Is it more complicated than that? I do plan to buy a plug that's water tight.
Thanks in advance!
By Callie
By Kingfish
