Hi, I’ve recently purchased an Ag Pro 1200 to find that it doesn’t have engine breaking. I live on a very steep property and it feels dangerous not having it. Does anyone know if it can be added? Or any other ideas? I’m mostly using it for weed spraying using a hand held wand… so I need to creep along stopping and starting. Thanks for helping.
  • 6 months later...
Look into a DURACLUTCH system.  Don't know if they have one for your model, but maybe they could make one?  Great system, works amazing on my Ranger 900.
https://www.duraclutch.com
    • By boydog40
      thanks guys
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By mark walkom
    • By Xov
