This is what the top of a T 2 looks like
By Jerrys500
Thanks Jerr
By Karlibob
By Travis
The cables are sort of seized up on the emergency brake, they still work but i have to wiggle and pull on em to get them to release, i pulled the drum off but cant see a way to remove the cable. It is kind of dirty inside the drum where it was leaking so i need to run to the parts store and buy some parts cleaner so i can see everything better.
The shop manual i have does not cover parking brake cable removal, well.... it does kind of. it says "Remove parking brake cable at both ends" 🙄
We'll see
EDIT: ARRR! Looks like my rear axle seal is leaking, there is a small puddle on a machined step below the seal and it smells like Trans oil. felt around the wheel cylinder and it isn't coming from their..... I guess my weekend is planned for me LOL
By CYJSP2009
Joyner 650 commando rear differentail and its parts are avaialbe now.
Qty is limited. Any one who is in need please contact [email protected].
By Dpken38
I have to rebuild the top end of my hisun 450. Can I replace it with a 500 cylinder kit without any other modifications?
