I have a check engine light on, buggy still running good though. I found the code by cycling the key on/off three times 0850, but I don't know what it is for sure. Does anyone know where to find what these codes mean?
Thanks. Dan
  • Alex changed the title to Massimo 450 check engine codes
From what I understand, a 10=0, so your code would be 0337. What it means? Don't know, I'm still trying to find a good source for info....on an automobile it would be a crankshaft position sensor code
    • By Duane Baker
    • By aefron88
    • By SSgt1994
      Myron
