Moab Trooper
By Greg Kilgore
By camojay
1400 miles on it
20240817_133539_1.mp4
By sxr951
By Joe Breaux
just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought a C FORCE 600 ATV to replace an old and well used Honda that finally after 18 yrs gave up a rod bearing. So far the new one has really impressed me .. I like the new Power Steering and this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas . It also has something I have never seen. Its EBS engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
By BuggyBoy
So these Giant 48v/110ah batteries have just become available: https://www.aussiebatteries.com.au/giant-100ah-48v-lithium-golf-cart-deep-cycle-battery
They look like they could drop in either side of the Controller that sits in the middle of the tray as they are 330mm(W) 355(L) 295mm(H). They can be paralleled, and I think two should be enough. Technically once paralleled the system should output 400ah continuous and 800ah Max (5 secs), more than enough for the E1 - probably 1/3rd more than is needed.
However, the sales person stated that if the regen braking exceeded 400amps, it would put the batteries in standby mode for protection and they would have to be 're-started' with a jumper pack to reset them. Does anybody know the max output of the E1 Regen system, and if it does exceed that, is it possible to disable/bypass the regen so it has a zero output?
Thanks.
